Customizing your Hub's sign in page
 To customize your sign in page, go to Settings > Advocate Program > Sign-In. The content you enter here will appear on both the Sign Up and Sign In pages.
You can use markdown to format the text in this area as well as insert an image. If you insert images, the sign in message area will resize to accommodate. Use this guide to see how you can format text and embed images using markdown: https://vip.influitive.com/help/markdown
Examples
The markdown in the above image results in the following:
Example of a mixed markdown formatted text and image sign in page:
Example of an image-only sign in page:
