Setting Up The Influitive API Integration
Setting up Influitive API integration give you the authentication token and permissions you need in order to make calls to the Influitive API.
To get started:
1. Login to Influitive, and click the cog wheel in the top right corner of Admin View and select Integrations from the dropdown menu.
2. Under Categories go to Marketing > Influitive API > Manage
3. Click on the Setup tab.  This will reveal your Authorization Token and X_ORG_ID, which you may need when making calls to our API or completing your referrals 2.0 integration with Salesforce.
For further documentation on the Influitive API, please consult our API Documentation here.
